| After some calculations... Assumptions: Before turbo: 80F, 14.696 psia (1 atm) After turbo/intercooler: 120F, 34.696 psia (2.36 atm) Before the turbo you have lower temp, lower pressure, higher velocity air. After the turbo you have higher temp, higher pressure, lower velocity air. The convection coefficient of air in the two states differs only slightly. Warmer, compressed, lower velocity air removes in the area of 53% more heat (from the MAF sensor). From the RPM range of 2000-7500 RPM the max difference (calculated) is 54.1%, minimum 53.1% Unfortunately pressure has a large effect on it. The differences at 24.7 psia are 27.5-28.8% So in order to work the correction circuitry must also have a pressure transducer to correct to the pressure also. I can make the circuit, who wants to give it a shot? :)
